HDMI cable max length?
17 minutes ago, Revontuli said:So I can just assume it to work?
if they're selling a 20m cable, it's pretty sure to work, or else they wouldn't be selling now would they
of course it depends on external environment as well, say if you run a lot of cables in parallel, then crosstalk might be an issue
in a normal household, i dont think that's an issue
the transmitter's power is also a factor
HDMI is a digital signal, 1's and 0's
0 when below certain voltage to 0, 1 if above certain voltage to a certain limit
voltage will drops across cable length due to resistance
so there are two ways to increase signal integrity
1) use near max voltage of "1" to ensure voltage drop across the cable wont bring final output to below 1's minimum voltage (assuming it have high current limit)
2) decrease resistance of wire to reduce voltage drop (increase the area of conductor, aka thicker cables)
