Wifi card for new build?
Solved by Alex Atkin UK,
On 7/20/2019 at 6:54 PM, DrMacintosh said:This is by far the best value WiFi card on the market imo
Bluetooth and AC WiFi. I use it an I've never had any driver issues or connectivity problems. It's a very reliable wireless card.
I prefer https://amzn.to/2yhj0BR as it uses a modern M.2 card that can easily be replaced with an Intel AX200 for the very latest in WiFi technology.
The Gigabyte uses an old miniPCIe card which are pretty much unsupported these days, so you won't find a card any better than what it already comes with, making it more expensive if you want to upgrade later.
