CPU Air cooler suggestion
Solved by Aerpoweron,
Damn. So back to the AMD stock cooler and then do some research which cooler really would fit and looks good to you.
https://noctua.at/en/products/cpu-cooler-retail/nh-u12a/specification
3 mm too high (158mm and your case has 155)
Mabe you risk it, and send it back if it does not fit?
Featured Topics
deanx ·
Posted in Troubleshooting1 -
Bkstrat ·
Posted in Troubleshooting0 -
3
remo233 ·
Posted in Power Supplies4 -
2
3
VioletGiraffe ·
PietervdWiel ·
Posted in New Builds and Planning8 -
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
