M.2 compatibility with Asrock z97 extreme6
Solved by JoostinOnline,
If you use the correct slot (the "Ultra" one that's gen 3), then yes. But keep in mind that there is little to no benefit to getting an NVMe drive for most people. The random read speeds are about the same as SATA drives (it varies by model), which is where most of the performance improvement comes from.
RTX 3090 ·
6
6
porina ·
Posted in New Builds and Planning12 -
Rothinsky ·
Posted in Troubleshooting2 -
skayqz ·
Posted in Graphics Cards7 -
Ricodotsh ·
Posted in New Builds and Planning15 -
5
