What's the difference between these two?
Asking for a friend, what is the difference between these two?
The seller's description on them says that B is the AURA remote control w/ panel, which costs 2$ more than C which is labelled as the Normal Remote Control w/ panel
What is the difference? Why is B more expensive than C? They seem to be both from the same brand (COOLMOON) please help. Seller is Chinese and friend is new to PC building but can only afford this. Thank you!
CCCC_n.png.fb450d0f66731850e10e8285dbaf272f.pngcheapsa.png.e016647f9fb6098dc808a93889b45744.png
Motherboard: MSI B450m Mortar Max
Processor: Ryzen 7 2700 w/ Wraith Prism
RAM: Klev Cras X 3200mhz 8gb x2
GPU:  Zotac Mini GeForce GTX 1070ti 8GB
PSU: Seasonic GX-750
Case: Inplay Robin 101 + 10 fans w/ hub and remote
Storage: Toshiba 1TB, Western Digital WD Green 1TB, Crucial BX500 480GB
https://linustechtips.com/topic/1075849-whats-the-difference-between-these-two/
The first one has the second plug which connects to AURA on motherboards for syncing with the motherboard lighting controller.
Oh so will it work with my mobo then? Mine is an B450m Bazooka Plus...
Your motherboard does not have aura.
do ASUS mobos only have Aura and which do you recommend we get then?
Only certain asus motherboards that support aura.
If you don't have one of those boards then the extra aura plug is useless to you.
Thank you so much! Looks like we'll be getting the cheaper one then!
5 hours ago, LogicalDrm said:
Imo they both look just same cheap RGB fan packs.
Yea but what's the best choice then
If that's the price difference, one with more features. Or longer warranty. Or no fake reviews.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Would the hub still run even if I don't have the AURA thingy?
4 minutes ago, LogicalDrm said:
Yes. Those have remotes for that reason.
Thanks! Looks like just gonna get the Aura then even if it costs more
13 hours ago, kidroc666 said:
ya get the mopre $ one for the future if you upgrade your broad you'll have the sync one already..
That's good. Thanks!
