Posted June 10, 2019 Author Added a 120mm fan. The GPU tops out at 65-70C compared to 80C+, but the system is quite clearly a lot louder now (>>>27dB rating LOLLL). Hottest part of the case is 5C over ambient; previously it was maybe 20C over ambient. Thanks for the help. 11 hours ago, jonnyGURU said: You're GPU mining in a tiny 88R. Of course the case is getting hot. Only 1 GPU 12 hours ago, Tristerin said: Yes GPU mining is profitable. BTC Exchange market. Mine low level coins, exchange for BTC. I do so on my Furys when at work. And CPU mine. 1700's do work. Is it any more profitable than Nicehash? Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Using case picture i can tell that some fans pushing air into oposite side, thats why where it should be coldest it is most hottest part in whole case because intake and exhaust fans pushing air into each other. CPU: Intel I7-8700K | Motherboard: Gigabyte Aorus Z390 Master | RAM: Corsair Vengeance 3000Mhz 2x8GB | GPU: Asus ROG 1080Ti OC | PSU: Seasonic Prime 650W Titanium | SSD: 1x Samsung Evo 970 250GB M2 1x Samsung Evo 970 1TB M2 | CPU COOLER: Noctua D15 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Author 1 minute ago, speed258 said: Using case picture i can tell that some fans pushing air into oposite side, thats why where it should be coldest it is most hottest part in whole case because intake and exhaust fans pushing air into each other. It has only one exhaust fan though out of the box Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 1 minute ago, NunoLava1998 said: It has only one exhaust fan though out of the box make sure that exhaust fan is actually pushing out of case air instead inside case(it happens from time to time where exhaust fan is actually pushing air inside due to wrong install side) CPU: Intel I7-8700K | Motherboard: Gigabyte Aorus Z390 Master | RAM: Corsair Vengeance 3000Mhz 2x8GB | GPU: Asus ROG 1080Ti OC | PSU: Seasonic Prime 650W Titanium | SSD: 1x Samsung Evo 970 250GB M2 1x Samsung Evo 970 1TB M2 | CPU COOLER: Noctua D15 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Author 5 minutes ago, speed258 said: make sure that exhaust fan is actually pushing out of case air instead inside case(it happens from time to time where exhaust fan is actually pushing air inside due to wrong install side) It's exhaust; even then I've already installed an intake fan recently (see above posts) and the cooling is good Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 3 minutes ago, NunoLava1998 said: It's exhaust; even then I've already installed an intake fan recently (see above posts) and the cooling is good also in which side your cpu fan cooler pushing air? PS. I suspect that intake or exhaust fans doe not provided needed airflow(too slow in RPM or too small in diameter 90mm or below), forcing air to stay in case CPU: Intel I7-8700K | Motherboard: Gigabyte Aorus Z390 Master | RAM: Corsair Vengeance 3000Mhz 2x8GB | GPU: Asus ROG 1080Ti OC | PSU: Seasonic Prime 650W Titanium | SSD: 1x Samsung Evo 970 250GB M2 1x Samsung Evo 970 1TB M2 | CPU COOLER: Noctua D15 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Author 46 minutes ago, speed258 said: also in which side your cpu fan cooler pushing air? PS. I suspect that intake or exhaust fans doe not provided needed airflow(too slow in RPM or too small in diameter 90mm or below), forcing air to stay in case I already installed the fans and they're working okay. I have no idea about what side the CPU cooler is pushing air lol Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 10, 2019 Just now, NunoLava1998 said: I already installed the fans and they're working okay. I have no idea about what side the CPU cooler is pushing air lol try take as thin as possible paper and put near cpu fan and you probably will know results CPU: Intel I7-8700K | Motherboard: Gigabyte Aorus Z390 Master | RAM: Corsair Vengeance 3000Mhz 2x8GB | GPU: Asus ROG 1080Ti OC | PSU: Seasonic Prime 650W Titanium | SSD: 1x Samsung Evo 970 250GB M2 1x Samsung Evo 970 1TB M2 | CPU COOLER: Noctua D15 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
