Does my old harddrive affect performance of system?
Hey everyone,
I've been having a-lot of "freezes" and lags on my system. But while it's a brand new system with 32gb ram, RTX 2070 and a Ryzen 2700x.
im still having this issue, now im asking you. Could my harddrive be the issue? anyone know?
i have 240gb kingston SSD for my windows and only that (had it since my pc from 2014-15) and when i upgraded motherboard and stuff, i made a install of windows 10 where it deletes programs but not files.
Then i have Crucial® MX300 750GB 2.5" SSD for games and important programs. (end of 2018)
And then i have a 2tb hdd from Western digital Green from the first desktop just like the ssd (2014-15)
Any suggestions?
- Matthias
Check with Hard Disk Sentinel. Usually, a drive affects only what is on it.
It might be that the Kingston needs a new firmware and a Secure Erase to restore performance.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Look at your error logs in Event Viewer and see if anything is there. Unlikely that the HDD being present will do this to your system, the system would have to be actively accessing a faulty drive to cause freezes as you've described. Much more likely that your SSD is causing this issue which will require some diagnosing.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
How do it get the kingston firmware updated as you suggest? ?
Could try going to 'Device Manager' and right clinking on your drive and selecting 'Update Driver'? Failing that, go to the manufacturers website.
Current PC
CPUIntel Core i9 9900k
GPUGTX 1080 8GB FTW EVGA
MotherboardASUS PRIME Z370-A II
RAM: Corsair Vengeance LPX (2x8GB) DDR4 2400 Mhz
Storage 1: Samsung 850 EVO 250GB
Storage 2: Hyper X 240GB
PSU: Corsair RM750 80 Plus Gold 750W
Peripherals: Logitech G502 Hero//Corsair K70 MK 2 Cherry MX Red
Display: BenQ XL2430T 24-inch 144Hz
Device manager has never updated any drivers for me ?
I've always been in the same boat, but recently I thought I'd go on a mass updating spree, and I updated at least 5 things through it.
Current PC
Do you have a link to the official Kingston update thing you where talking about?
I'll try the same when i get home ?
Could my "not" complete windows install cause issues? old drivers and stuff from the components that is from the first pc?
I assume you mean that you selected save all files, like your documents and stuff when you performed your new install? If this is the case that shouldn't be a reason for performance issues. What is it that you're having issues with exactly? Like what are you doing when the freezes occur?
Current PC
I made these posts which tells the issues more fully.
But people stopped answering, so went to create a new one
You simply go to Kingston's webpage, find your drive model somewhere (probably support) and there you'll have the downloads for it.
I think the tool is called Kingston SSD manager or smth like that.
Ah I see. Do you have any issues with general windows? So like exploring files, browsing the web, watching videos video Netflix, YouTube etc?
Current PC
I feel my system running slow at some points, and can freeze at times. but its mostly in games. but slow web browsing (i have good net tho)
Well because you've got your games on a separate drive, I'd be led to believe that could also be the problem, but it does sound like it's your OS' drive as that would also have an effect on your games. I think, if it's that much of a hindrance to your machine, you might be best off saving all of your documents (to a cloud or USB or something) and resetting your PC fully. And then reinstalling all of your stuff. I know this is a hassle, but if the problem is still there after doing this, it kinda finds the solution to your problem, which would probably be to load your OS onto a different drive, or buy a new drive as well. BUT FIRST BEFORE DOING ANY OF THIS, UPDATE YOUR SSD' DRIVERS! https://www.kingston.com/en/support/technical/category/ssd
Find which one is yours from here!
Current PC
Since 2007 I have used only one drive in my gaming PCs and those drives have been WD 10,000rpm Raptors. From those I went straight to large SSDs.
I started using 10,000rpm dives to fix the stutter problem I had with MS Flight Simulator and the game, Oblivion. Both are open world and both had lots of user added content(mods).
I improved performance even more by removing all other drives from the system. Windows liked to "check disks" and that slows things down. Windows may have been fixed but I have not checked in over 10 years so I would not know.
The only type of stutter that I get now is from GPUs. Usually from drivers that can be rolled back to fix.
In one case it was a motherboard/GPU compatibility problem. This was easy for me to test since I don't sell my old GPUs. I simple put another GPU in and did some tests.
What I do works for me and has been working for a long time.
I recently fixed a problem I had with stutter I got from 4k textures in my heavily modded games by using a large 970 EVO. I was an expensive fix but so was paying $300 in 2007 for a WD Raptor.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
Thanks! :D
Can i find the version of my ssd on my pc or do i have to open the case up? ?
10 minutes ago, MatthiasLundgaard said:
Thanks! :D
If you go to 'Device Manager' and then 'Disk Drives' it should have then listen there, and one should be called 'KINGSTON' followed by some numbers or something, that's what model it is.
Current PC
I'll return to this topic later, when im done with work and have tested the things that have been suggested in the thread! ?
If you have ANYTHING on the HDD that your system uses, it'll seem to lag when accessing said stuffs.
For example if you installed Discord on your HDD by accident, you'll get a lag feeling when Discord loads on boot.
Something to check.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
