Fan Hub/Controller For Water Pumps (Emphasis on Plural)
Solved by W-L,
36 minutes ago, Daharen said:As a side note would two Laing D5 Plus pumps outperform four Laing DDC-1T Plus pumps in total flow rate?
What are you planning that will require 2 or more pumps in series, I'm assuming this is due to a requirement for head pressure?
To answer the question you can use a power hub to have a singular PWM control line come in a group control all your pumps so they run at the same speed. Something like this from Swiftech will work well.
http://www.swiftech.com/8-WayPWMsplitter-sata.aspx
As for pump option if you just require a large amount of head pressure I'd suggest to just get one of these as it will have a substantial performance over combination of DDC's or D5's.
