Need help with updating Zotac GTX 1060 6GB AMP!
Solved by Skiiwee29,
well first off, you have the card likely installed in the wrong slot of your motherboard since its running in 8x instead 16x. It should be in the upper most slot. This doesnt affect gaming performance, but can affect thermals from less air flow the lower in the case it gets. As far as BIOS flashing, here is the BIOS you need:
https://www.techpowerup.com/vgabios/211110/211110
and here is the instructions on how to do it:
https://www.overclock.net/forum/69-nvidia/1523391-easy-nvflash-guide-pictures-gtx-970-980-a.html
