Hello,i have very big problem. My PC is 1 month old and all games are running bad for me. Evey game got +- 50FPS less then on all benchmarks on youtube.
 MB MSI B450 TOMAHAWK - AMD B450
CPU AMD Ryzen 7 2700X
PSU Seasonic Focus Plus Gold - 750W
GPU MSI GeForce RTX 2080 Ti VENTUS 11G OC, 11GB GDDR6
HDD Seagate BarraCuda, 3,5" - 2TB
SSD Crucial MX500, 2,5" - 500GB
RAM Kingston HyperX Predator 32GB (2x16GB) DDR4 3200
I post here DxDiag and HardwareMonitor from game Kingdom Come Deliverance.
Same like this game is running all of my games..
Im playing all games in 1080p and my main monitor is Samsung S24F350 - LED monitor 24"
my second monitor is only 1680x1050,so im using it only on FB,Youtube etc...
Please help me with my problem,im really sad bcs of this..i paid for best and i havent the best..
DxDiag.txt
HardwareMonitoring.hml
https://linustechtips.com/topic/1065501-rtx-2080ti-ventus-problem/
DxDiag.txt
That's a 60Hz monitor 1080P monitor.
Make sure V-SYNC is disabled.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
Were those Youtube benchmarks using an overclocked i9-9900k at 1080p? 1080p tends to be fairly CPU-bound at higher frame rates.
AMD Ryzen 7 3700X | Thermalright Le Grand Macho RT | ASUS ROG Strix X470-F | 16GB G.Skill Trident Z RGB @3400MHz | EVGA RTX 2080S XC Ultra | EVGA GQ 650 | HP EX920 1TB / Crucial MX500 500GB / Samsung Spinpoint 1TB | Cooler Master H500M
Do you have any overclocking done? I have the same processor, a x470 board and a 2080ti and as you see you are outscoring me, Im running stock settings on my gear and have zero issues with low frame rate. If you have OC done on any of your stuff maybe its not as stable as you think?
Yep i got overclocked GPU,bcs of problem with low FPS which i had before too..wait a minute,i will cancel that overclock and try it again
So this is without overclock
4 minutes ago, Ravendarat said:
Also what kind games are you playing, are they more GPU dependent or CPU?
and im playing games like GTA5,KIngdom Come,PUBG,AC Origins,Escape from Tarkov etc...on every game i got +-50fps less then guys on youtube videos with same CPU and GPU
What're your background processes lookin like prior to launch?  Check your CPU/GPU/HD usesage prior to launchin them, if you don't know.  There could be a background process issue that's come out w/the constant big updates to Windows 10 as of late - I had an issue w/my HD throttlin to max usage while idle for no reason, which tanked my games.
I've seen other similar reports, which's likely why they're sendin out so many patches in an attempt to fix the issues.  YouTube channels have also stated Microsoft knows about the issues.
Primary
OS:        Windows 10 - Professional (64-bit)
CPU:      i9-10900k 3.7-5.3GHz (10th gen)
GPU:      EVGA RTX 3080ti FTW3 Ultra Gaming 12gb
MB:         ASUS RoG Maximus XIII Hero (ATX)
RAM:      64gb (4x16) DDR4-3200MHz G.Skill TridentZ Silver/Black (CL16)
HD:         1x 8TB Corsair MP400 NVMe PCIe 3.0 (SSD)
               2x 16TB Seagate Exos 7200rpm (HDD)
E-HD:     12TB WD
PSU:       EVGA 1000w G2, 80+ Gold (modular)
UPS:       900w CyberPower
Display:   ASUS 27” 1440p/270Hz IPS 0.5ms (XG27AQM)
                Aorus 27" 1440p/165Hz IPS 1ms (FI27Q-P) iGPU
KeyB:      EVGA Z15 (wired)
Mouse:    Logitech G-502 Hero (400/600/800/1000)
Headset: JBL Quantum ONE Gaming Headset
Case:      Cooler Master MasterCase H500P Mesh (ATX)
Other:     XB-1 Wireless Controller Adapter w/Controller
              NPET H01 Gaming Mouse Bungee Cord Holder w/4 USB Ports
Gaming Computer Specs.pdf
