Premiere Pro, scale 1080p to 4K or 4K to 1080?
4 hours ago, Bajantechnician said:Hey Ryan Havent seen you for a while haha
Would using the scale to frame function on a 1080p -> 4k clip create any pixelation? Or does premire work differently from the way im thinking? Im afraid that essentially blowing up a 1080p clip into 4k will introduce pixelation because the image is getting stretched 4x than it actually is. If that makes sense. Kind of rambling now lol.
I'm not sure what scaling premiere uses for video, if it's nearest neighbour, linear, etc. I would guess linear. Of course 1080p footage will not look as good as 4K footage when viewed on a screen that can actually show you the difference, but it may be worth being able to get more out of the rest of the footage. You will have to decide that. For example, if the low res footage makes up just a small part of the overall project, like the 6 o'clock news showing a grainy smartphone video shot vertically, then you would just insert that, understanding that it's a small piece and there's nothing you can do about it. You wouldn't downscale the whole project to match that lowest denominator just so it's all equal. However, if it's a considerable potion of the total, perhaps you want to accept that that's the best you can export and scale down the rest to match.
