Tilting pc tower case on its side
Solved by TVwazhere,
4 minutes ago, cnorberg said:If you have a pc tower case and it’s water cooled can the case be tilted on its side in order to access your hard drives or ram sticks by taking off the side panel of the pc case?
Is it the same for all pc tower cases that are water cooled that you can tilt them?
Yes and yes. I've tilted mine plenty of times that had an AIO. As long as you dont run a pump dry (assuming its a custom loop) then you'll always be good.
