depends. imo watercooling is only worth it when you go custom watercooling, so you can get a specific loop for your hardware requirements.
that being said, if you are going for a case with restricted airflow you might be better off getting a AIO.
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12536013
Even the Dark Rock 4 is sufficient for the i9 9900K.
If you want to ensure a high end overclocking and what not though might go for the Dark Rock 4 Pro.
AiO's are extremely overpriced and overrated.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12536034
The Dark Rock 4 is 68.99
The cooler Master ML240L is 69.99 for a 240 AIO. I'm not sure where you're getting they are overpriced.
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12536053
Probably because the Dark Rock 4 is a high performance cooler with premium high quality heatsink and dead silent high end fans that outperforms the ML240L at everything because the ML240L is an entry level AiO with bad thermal performance, loud fans and very prone to pump failure.
Personal Desktop":
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12536075
According to Tom'shardware testing, the cooler master ML240L out performs the Dark rock 4 in cooling, but is indeed louder. I was just commenting that AIO's can be had for very reasonable prices. Also the Dark Rock 4 is more of a mid range air cooler, while the Dark Rock Pro 4 is the high end variant.
https://www.tomshardware.com/reviews/cooler-master-master-liquid-ml240l-rgb,5345-2.html
https://www.tomshardware.com/reviews/be-quiet-dark-rock-4-cpu-cooler,5563-2.html
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12536095
Water - Reaches Thermal Equilibrium Slower, Cools back down Slower
Air - Reaches Thermal Equilibrium very quickly, Cools back down very quickly
Both work very well.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12536128
Aio will last you maybe 2 years before it degrades or dies,
Air cooler will last you 2 decades for the same or better performance to noise ratio,
choose yourself.
CPU: Ryzen 7 5800x3D | MoBo: MSI MAG B550 Tomahawk | RAM: G.Skill F4-3600C15D-16GTZ @3800CL16 | GPU: RTX 2080Ti | PSU: Corsair HX1200 |
Case: Lian Li 011D XL | Storage: Samsung 970 EVO M.2 NVMe 500GB, Crucial MX500 500GB | Soundcard: Soundblaster ZXR | Mouse: Razer Viper Mini | Keyboard: Razer Huntsman TE Monitor: DELL AW2521H @360Hz |
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12538082
Get DRP4 if you dont like Noctua color scheme, otherwise get the NH-D15.
Dont bother with AIO's. While a 360mm AIO can beat top end air coolers, they are damn expensive and will be noisier.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1060588-aio-or-not/#findComment-12538339
