Noctua NH-D15 will fit with G.Skill trident z rgb 16gb ddr4 3200mhz ?
Solved by Ankerson,
7 hours ago, MU5TANG said:Hi, i'm new to PC Building.
<main-stuff>
I wanna ask, is Noctua NH-D15 air cooler will fit with G.Skill trident z RGB 16GB dual channel RAM?
Yes it will, I am using an NH D15 with Trident Z RGB currently.
Just have to raise the front fan to clear the ram.
1
Anbublackops ·
Posted in PC Gaming4 -
1
JJ7 ·
Posted in General Discussion0
play_circle_filled
Latest From Linus Tech Tips:
Why it Was Almost Impossible to Put a Computer in Space
play_circle_filled
Latest From ShortCircuit:
I’m kind of an iPad hater, but this is MAGICAL. - iPad Pro M4
