Help with my RAM pls
Solved by LukeSavenije,
should work fine, tho I'd manually overclock it with 1.35 v on the dram, 3200 mhz (or higher if you can reach) and cl16, as ryzen isn't that stable with odd timings
Featured Topics
pourint ·
Posted in Troubleshooting1 -
2
5
1
skayqz ·
Posted in Graphics Cards12
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
