Is a loose battery in a phone bad?
Solved by LamoidZombieDog,
i dont see how your battery could be loose. One, how would you know its the battery? and two its a phone. its not like it has space for the battery to slide arround. Being its a phone, you should be fine it cant move very far, only a few mm if that. though to fix it, all you have to do is open it, lift up the battery, put some battery tape or any double sided tape on, and stick it back down.
