A small fire on my mobo for the last couple years?
Solved by Spotty,
8 hours ago, f2bacon said:Windows 10 pro 64bit
nzxt h440 case
gigabyte gtx 1060 3gb windforce
Amd fx-8150
nzxt kraken x52 240mm aio24gb ddr3 1600 ram
the motherboard shows up as a gigabyte 2ac8 but the code in the inside is m3970bm
Not much point spending money on an old system like that. Better off putting the money you would spend towards a new system.
Keep the graphics card, the case, and the AIO cooler. Sell the CPU and the DDR3 RAM. Dispose of the dead motherboard and damaged PSUs.
Buy a new CPU, motherboard, RAM (DDR4), and PSU. I would also recommend an SSD if you don't already have one for windows.
