Will a Noctua NH-D15S be enough for a 9940X?
Solved by Taf the Ghost,
8 minutes ago, fxscreamer said:I have a 9940X on the way (14-core) since my current system died, and currently have a NH-D15S inside a Fractal Design R6 TG with the stock case fans. I don't plan to overclock anytime soon at the moment since I just want stability for now. I might run XMP 3200 on my ram, but that's about it. Will this be ok? Noctua says it'll work on Basin Falls 2066, but with that many cores, I was curious if anyone had experience, let alone knowing what type of headroom I have.
You'll be fine. If you try to hit 5 Ghz, you'll have problems, but at stock you'll be more than fine. Might want to make sure you have the mounting parts, though, as you might need to order new ones for the X299 platform if they aren't in the box.
