What switches should I get?
Solved by seon123,
SMD lighting is when the LED is right on top of the PCB, instead of on top of the switch with a through hole LED. Cherry RGB switches also only support SMD lighting, so you should be fine.
SMD
Through hole
All the switches do, is closing a circuit. That's it. It's as simple as it can get. So that's not something to worry about.
Featured Topics
UGAATL ·
1
4
Mark Kaine ·
Posted in Displays3 -
3
3
tippytipper ·
Posted in Storage Devices2 -
2
AlyShazli ·
Posted in New Builds and Planning24 -
4
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
