Looking to build a new computer, my old 3.0ghz am2 with a Radeon HD 6750 and 6gb of ram just isn't cutting it, lol.
I am looking at a am4 2400g with 16gb of ram and a GTX 1070 TI. I am trying to find a power supply with an 8pin CPU connector and another 6 and 8 pin connectors for my video card.
Would prefer something off Amazon Canada so it can all be shipped together.
https://linustechtips.com/topic/1046427-looking-for-a-power-supply/
Seasonic Focus Plus 550W.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
Get a better MOBO as well. GB DS3H is pretty basic model. Recommended B450 boards for gaming IMHO MSI B450M mortar, B450 Tomahawk, B450m gaming plus& asrock Fatal1ty Gaming K4..
And consider Ryzen 2600, roughly the same price as 2400G, but more cores-more threads, better performance. And actually almost the same price..
And get faster rams, 2400Mhz is way to low frequency, Ryzens benefit a lot from 3000+ MHZ clockspeeds.
Also, there is no point in choosing M2 SSD for general use&gaming. During these tasks, you won't notice any difference compared to standard ssd-s.
Life is really challenging. I don't always suceed: )
M.2 is just a form factor and has nothing to do with speed. You're thinking of nvme SSDs.
The Kingston uv500 is a SATA based SSD. Whether it is in m.2 or 2.5" form factor it still has the same SATA based performance.
Everything else you suggested is great advice though. Ryzen 2600 would be better than the 2400G since they're using a dedicated GPU. Faster memory, better motherboard would be good as well.
Thanks for the input. googled for it, and realized I was not right. Thanks for clearing this up.
Why?!
So that he has reboot issues with the next high end GPU??
13 hours ago, D_r111 said:
Great, thank you
There are better units available for example Bitfenix Formula, be quiet Pure Power 10/11.
"Hell is full of good meanings, but Heaven is full of good works"
1 hour ago, D_r111 said:
Any better?
No
YOu don't need no 700W
you need a good quality PSU!
Even a 400W would be enough without OC though maybe cuttin it a bit close.
Reasonable would be a 550W Bitfenix Formula, if the price is right Silverstone Strider S.
33 minutes ago, Stefan Payne said:
No
Let's not get into it here, but the Formula 550 isn't the best PSU (not modular) for that POS case with very little cable management space
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
That even makes it better because you don't have the space of the connectors.
THe Formula is as basic as it gets, so that makes it optimal for small units.
And for the one Drive Connector that's not used, you can use one of the supplied Zipties.
43 minutes ago, D_r111 said:
I was not big on the case either, would probably try and reuse me old antec 900 v2
Even more reason not to use a non modular PSU. Get any Tier B or above 550w semi or full modular unit.
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
 I'll go ahead and recommend what I bought. Prime 850 Titanium. It will be the second most expensive item in your build, but it might also be the PSU for life. I tend to overspend on important parts so there's that... ?
Edited by Cattrick
spelling is hard apparently
And, it's completely unneeded for 99% of people. There's a reason why it's up in the Tier S category on the list; it's extremely expensive and your average user will gain nada from it.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Oh, bitfenix whisper M 550 is approx 100$, modular, gold. I love it. The 450W would be enough though...
btw, why would you choose 1070ti instead of 2060 or 1660ti? Former beats 1070ti&latter only lags behind ~10%.
He's looking at Canadian pricing here.
13 minutes ago, D_r111 said:
I was looking at the bitfenix 550w as well but it was more expensive and not available with prime. I figured this one with 700w with an 80+ gold certification would be good. Is too much power a bad thing?
Are you close to a Memory Express or Canada Computers location? Amazon doesn't have many deals on power supplies.
Full Specs
Helios EVO (Main):
Delta - Laptop
I know. I just assumed, Canadian pricing is better-lower, because our local prices are waaay to high due to 27% VAT.
110 USD, ships from Canada
15 minutes ago, D_r111 said:
The closest canada computers is a 15+ hour drive without traffic, I may just have to get the Bitfenix Whisper 550w from a 3rd party amazon seller.
Newegg is also a good option. They over pretty cheap shipping to most of Canada.
If you'd be ok with buying refurbished go for
https://www.newegg.ca/Product/Product.aspx?Item=N82E16817139213&Description=CX450M&cm_re=CX450M-_-17-139-213-_-Product
Otherwise this would be nice:
https://www.newegg.ca/Product/Product.aspx?Item=N82E16817139146
Full Specs
Helios EVO (Main):
Delta - Laptop
