MY COMPUTER IS NOT GETTING ANY POWER
So i have a hp pavilion 580-023 its a gaming desktop and im not getting any power i put a new power supply in and new power cord, switched the ram around, ive been messing around with it to see if i can figure out whats wrong with it and i cant find anything, the old psu in it was 300w but i changed it out with a old 1000w rosewil that my uncle gave me. i think the mobo might be dead but if anyone has any suggestions im more than willing to try
Make sure you have every cable connected and that you have the switch flipped on the back of the PSU.
Make sure to quote or tag people, so they get notified.
This.
Could be a dead power supply, since its old and used.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Was it working fine with the old PSU? If so, I would ensure that your 24pin power cable to your motherboard is plugged in all the way (can be tough sometimes) and that your power switch cable didn't come loose.
To test the PSU look up how to start it with a paperclip. If its not one of those silent models where the fan only runs when it needs it the fan should kick on when you flip the switch.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
1 minute ago, Eastman51 said:
This.
i was just using it last night i was playing black ops 4 and than it just turned off out of no where
Power supply probably died. Put in the old power supply and test it
*GPU Test Bench*
Did you break a warranty seal when you switched the PSUs? If not, I'd put the original back in there and RMA it. You should still be in warranty on a Kaby Lake desktop.
Aerocool DS are the best fans you've never tried.
check for leaked capacitors?
ya i was using the psu for like 5 months or so  and i switched psu to the stop one to see if the psu was dead and still nothing no fans turn on no hdd spinning
what would that look like?
i switched the case it was in and been doing little upgrades here and there but like nothing major just adding fans and stuff and rgb so i can be a cool kid xD
Try unhooking the GPU and see if it boots.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
4 minutes ago, Invisible tech Budjanovci said:
Image result for leaked capacitorImage result for leaked capacitor
ya none of my leaked
i tryed and still nothing
Sounds like the motherboard is dead. I would suggest not using that Rosewill PSU again.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
so should i get this mobo just to try it and see if thats it https://www.amazon.com/Biostar-Motherboard-Tb250-btc-Lga1151-Express/dp/B072LXX4NF/ref=sr_1_1?crid=35ARJYBI7T8PX&keywords=lga+1151+motherboard&qid=1552596070&s=gateway&sprefix=lga%2Caps%2C153&sr=8-1
i im not trying to build this pc up. im gonna build a new pc later this year i just wanna make this one work
As long as your current CPU will work with that board you can try it. I doubt that board will fit in your case though. HP, Dell, etc. don't conform the ATX standard and use their own form factor instead. You could lay the motherboard on a cardboard box and test it. Is it worth it? Meh, if you're upgrading this year anyways I wouldn't.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
oh no its not in the stock case its in a case my uncle gave me the case is  from like 2008 or something its a old case but my uatx mobo fits in there with alot of room to spare. like this case is back when the bigger the case the better. i had to buy a laptop desk just for my pc to sit on lol
