7700k 7700k to Hot?
Solved by TheElectronicGeek1,
2 minutes ago, Millhaws said:Okay I just set the voltage to adaptive mode and noticed no difference in temps. I don't see where to set the clockspeed to adaptive though and my core clocks are set to 4.5GHz. but if that is normal than that's all that matters to me. i did take another screenshot of HWMonitor this time so maybe that will help a bit more but regardless this is the most help ive gotten on this issue so again thank you.
Check for speed step in the bios or some adaptive clockspeed. Also set your power profile in windows power settings to balanced. It looks like your clockspeed is still at the maximum so speedstep is off or your power profile is on high performance which locks it at full speed all the time.
