fookin nooice!!! ? 9/10
Current Build
CPU: AMD Ryzen9 5900X
CPU Cooler: Deepcool Gamerstorm Captain 240 Pro
Motherboard: ASUS ROG STRIX X470 Gaming-F
Memory: G.Skill Trident Z Neo RGB F4-3600MHzC16D 2x16GB
Video Card: EVGA 3080Ti FTW3
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case
Power Supply: EVGA SuperNOVA G2 850W 80+ Gold Fully Modular
Case Fans: 2x Noctua NF-P14s redux-1500 PWM 78.7 CFM  140mm Fan
Monitor: HP x34
              LG 29UM69G
Mouse: Razer Basilisk
Keyboard: Razer Blackwidow Chroma V2
Controller: GameSir Tarantula Pro
Headphones: Sennheiser IE200 + Fiio BTR5 2021
Speakers: Logitech Z200 2ch Speakers
OS: Windows 11
8/10, i have seen better but I have also seen the back of my pc. I'd be more than content.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
I would say a 6, maybe a 7. Need to really clean up that spider web of a mess at the PSU opening. Using the channels are great, but once you get below them, you are very disorganized and all over the place with no tightness to the cables etc. Use Velcro straps, zip ties, etc to clean that up and it will easily push it up to an 8 or 9 at that point.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
1 minute ago, Kibbz said:
I didn't know it was that good, thought maybe a 7
considering the case, what looks like stock cables and you haven't pinched them . I figure you've done well. The only way to do better is to get custom length cables. Which would help clear out the psu area. But getting custom length cables = higher level of scrutiny.
Current Build
Monitor: HP x34
              LG 29UM69G
OS: Windows 11
The way I see it is you are not using custom cables, so you have a lot of excess. Also I don't really see an easy spot to hide the excess cables. That's why I think it's a good job.
My System:
Yeah, the 24 pin atx cable especially is huge to fit well on the H400i, but I'll buy some zip ties tomorrow and try to neat it up a little better.
9 hours ago, Kibbz said:
Rate from 1-10
(I think is ok for my 2nd time)
About a 6-7. Which isnt bad, considering this is my idea of 10/10
Image result for define s2 youtube_buddy3012
I would say something like 6, 6.5
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
4 hours ago, Kibbz said:
Well, im sure that with custom lenght cables I could do that, but with stock cables its impossible
With the stock cables you did about as good as is reasonably doable. Custom cables seem to be considerably easier to clean up than stock cables, but as you build more systems you get better at it. [Build 2 and 3 respectively are Blue Build and Purple build]
20170521_204250.thumb.jpg.50a1d7ffe9271a8d492498b23317373f.jpg20180325_213718.thumb.jpg.7c3a650b0e0b92d2f53d3829742b4da9.jpg
