need help on all in one setup (Thermaltake water2.0 extreme)
Solved by acrain92,
well thought i would update this in case anyone happens to buy one of these coolers and has the issue i did i was able to fix it by using the drivers for the antec variant (different from the aforementioned thread it linked to the step below what i needed even though it was the same as well but it didn't have the rgb led control like the one i got to work) of the same acetech co. design as the pumps are the same just re-branded (at least i believe so lol regardless it works it just wont make use of the rgb led controls since its not present on the thermaltake one like the antech one)
