Planning an upgrade - need help with PCI lanes and MOBO!
Solved by Crunchy Dragon,
Just now, Electronics Wizardy said:Depends on the slot, but with most 115x board, there are 2 pcis slots using cpu lanes, either in 16x with one used or 8x 8x, the last slot at the bottom almost always using chipset lanes.
Thanks for confirming that.
@The Pikachu Mafia if you install it in the bottommost slot on your motherboard, then it should work.
From my online findings involving this capture card and SLI configurations, your system won't like booting with all of those at once and will instead either not boot at all, or boot to a black screen.
http://www.tomshardware.com/answers/id-3793742/pcie-configuration-elgato-hd60-pro-wont-boot-sli.html
It looks like unless the bottom slot does indeed run off of chipset lanes, you'll get one or the other.
