LG Monitor / Any Other Monitor
IKWeb
Hello All
I am looking for a new monitor, and have kinda a strange requirement.
I have been looking at the LG Ultrawide monitors, as I saw a video that would let you take 2 inputs and then display them on the monitor at the same time...
After doing some research today, I found this is called lg dual controller, but it looks like it will only work when you install software on both PC's.
My issue is one display will be from a PC, and the other, from my Nintendo Switch, so the switch I can't install the software, thus I am not sure if it will work as expected, or if the software is just so you can use the same mouse on both systems, and move files around. Which I don't need.
So what I would like to ask is
A) would this LG system work with the 2nd device been a switch
B) if not, does anyone know any other ultrawide units that can display 2 inputs at the same time, side by side.
Thank you.
8 hours ago, IKWeb said:
Hello All
Thank you.
Yes you can do it, just make sure it says picture in picture or PiP or PIP on the monitor specs.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
