In terms of case temperatures, how significant is 55 CFM?
Solved by Jurrunio,
200mm fan on the top? never heard of that
but the temperature difference will depend on the overall layout. If there's a big heatsink on top of the CPU then that 55CFM will give a significant difference. Otherwise, the difference should be small, not even that noticeable.
Featured Topics
Nexxus ·
2
PSP. ·
3
kennethk ·
Posted in Troubleshooting0 -
bsforyt727 ·
Posted in General Discussion4 -
3
7
