First computer build fail, need help
Solved by glenalz81,
6 minutes ago, Atlas270 said:I haven't updated it myself, no. But if you're talking about updating it to be compatible with my cpu, I've been told it comes already compatible with this cpu and has the "AMD RYZEN DESKTOP 2000 READY" sticker on it. I'm using an AMD Ryzen 3 2200g with a Gigabyte AB350M-DS3H.
As long as it says Ryzen 2000 ready that's fine. If your sure that your ram is compatible then most likely a board failure.
If you haven't yet, unplug everything not needed to power on, ssd/hdd/fans/contollers the lot then see if it stays switched on, if it does there's a problem with one of those, if not then i'd say RMA the board.
If you have access to another PSU would be worth a try aswell.
