rainbow six seige problem with choppyness
Guest
I play rainbow six seige a lot and experience some painful choppyness where my game seems not smooth and sort of laggy, although my frames consist of 100+ and I am using  144hz monitor, any solutions?
What is your system specs?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
3 hours ago, Brooksie359 said:
Are you having frame dips?
nah
cpu: i5-6400 2.7ghz
gpu: msi armoured rx 580
ram: 2 sticks of 4gb
need anything else?
1 minute ago, Fushiatic said:
nah
It could be your internet connection then. Also when I mean frame dips I don't mean dipping to low fps but rather large fluctuations like from 200 down to 110 or something of the sort.
Does the game do frame dips when you are attacking, like you enter the objective building or when you are defending?
other games are fine and my ping is always 20-60
no, just always choppy
Whats the settings set at?
high, medium, low, i've changed them a ton, turning off v-sync helps a bit
Is your RAM running in dual channel?
yeah, 2 4gb sticks
Turn down video settings and try again. Make sure you have latest graphics card drivers downloaded and installed.
fixed it when i set v-sync on amd settings to 'always off' or 'off unless application specifies'
Gotcha glad its fixed, good luck with the game.
