I7 9700K Not Turbo Boosting?
Ok Little Update, Problem is Solved!
Indeed Updating the BIOS Solved the Issue for me. It's Boosting as High as 4.6Ghz now!
I Updated the BIOS Using the Ez Flash 3 Functionality, go into the Bios and then use the Tool and it does it all for you. Thanks for the Help guys
By WPD Technologies
Started
By Grimet
Started
By Zarudain
Started
Posted in Troubleshooting3 -
By K1LLA_KING_KONG
Started
Posted in Programs, Apps and Websites1 -
By Gentleflamingo
Started
Posted in New Builds and Planning4 -
By Elon Moosk
Started
Posted in Laptops and Pre-Built Systems0 -
By SynapseDisruptor
Started
Posted in New Builds and Planning2 -
By ThatOneGuy21
Started
Posted in New Builds and Planning1 -
By PanKek
Started
Posted in Troubleshooting0
