what are these cables for?
By
TechRush
in Troubleshooting
in Troubleshooting
Solved by samcool55,
1 minute ago, 2018amdbuild said:each cable has multiple sata connector heads, can i use one cable to connect two hdd's to the psu or should i be using separate cables for reach hdd?
You can use all the connectors, if it fits, it sits, and it should work.
Rick13 ·
6
popularlion ·
Posted in Troubleshooting4 -
2
CallMe_David ·
FancyPants101 ·
Posted in Troubleshooting1 -
BoBo6107 ·
Posted in LTTStore.com Merch0
