Psu fan not working but when I spin it starts spinning
BDMD
So my older nzxt 850 watt psu fan won’t turn start spinning unless I spin it then it will continue to spin how do I fix
compressed air solves all. Blast it to try to clean it.
Primary PC:
Seems like it's time for a new PSU. I wouldn't try disassembling a power supply.
If you choose to get a new power supply try finding something from tier 1 or 2 that suits your budget:
Does it still not spin even when the computer is under heavy load?
I wouldn't get rid of a power supply because of a broken fan.
Just buy yourself a new 120mm fan and replace it.
Make sure to leave the power supply OFF and UNPLUGGED for 24-48 hours before you open it up, then it should be safe to touch anything. (In reality it's often MUCH faster than that, I'm just being careful.)
Any modern power supply will have bleed resistors to remove the dangerous voltages from the big caps (the ones that can hurt you.)
In double reality, it's quite often HARD to hurt yourself when just replacing the fan. The fan is attached to the top cover of the power supply, and all the dangerous stuff is underneath the board.
Well thanks guys I’ll see what I can do
Wich one of those?!
This one?
https://geizhals.de/nzxt-precise-850w-atx-2-0-prc-850-a285130.html
Or that one?
https://geizhals.de/nzxt-hale82-850w-atx-2-2-a706406.html
Maybe one of those?
https://geizhals.de/nzxt-hale90-v2-850w-atx-2-31-np-1gm-0850a-eu-a1174239.html
https://geizhals.de/nzxt-hale90-850w-atx-2-2-a557347.html
My guess would be the NZXT Precise...
"Hell is full of good meanings, but Heaven is full of good works"
Just now, BDMD said:
It’s the precise
thought as much...
REPLACE ASAP; DO NOT USE IT!
A good unit would be a Bitfenix Formula or be quiet Straight Power 11...
Ok will do thanks if possible why should I not use it
Sure.
1) because its made by a pretty bad manufacturer that no longer exists.
2) because its old and at the end of its life anyway, so it can die any day anyway
3) because its Topower, I wouldn't expect too good Caps either. Teapo would be fine, but they tend to use stuff like JenPo and the AsiaX/Fuhyyju and other lower end stuff you don't see nowadays
4) it was made in a different era for completely different Hardware, when there were no power saving things in PCs, thus no strong transients the PSU had to compensate for and other stuff...
In short:
Because its 11 years old...
1 hour ago, Stefan Payne said:
In short:
aging psu's=bad
thats why I replaced my 10 year old antec psu.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
