USB 3.0 PCI card help?
ZeusXI
Would there be a pci card that has usb 3.0 on THE INSIDE of the case? friend wants to know and i dont know any off hand and have been looking. he wants to put his external hdd inside his computer so he doesnt have to route the hdd cables to the outside and then plug them in. he wants to plug them into the inside.
u do have USB on the inside of the motherboard.
and yes i did see PCIE USB cards with USB on the inside.
there are usb pins yes, but are there adapters that connect to them so you can run cables in your pc?
Something like this?
One side Mother Board Pins the other USB Type A?
PS it is USB2 the USB 3 is a wider connector on the Motherboard.
YES! what is that called?
Two options:
  1. Take the HDD out of the enclosure. All external hard drives sold nowadays have a sata interface on the inside, all you need to do is unscredw the external hard drive and voilà, you have a normal sata laptop hard drive.
  2. Buy a USB 3.0 card with a 3.0 header, they are somewhat pricey tbh but here is one. Then, using a USB header to 3.0 adapter you can adapt to the hard drive USB cable. Much less elegant though. I suggest doing what i did in no. 1
https://www.scan.co.uk/products/silverstone-ec04-p-pci-express-card-with-4x-usb-30-ports
tfw someone posts a tech-related thread in "Off Topic".
Sorry for the mess!  My laptop just went ROG!
"THE ROGUE":  ASUS ROG Zephyrus G15 GA503QR (2021)
  • Ryzen 9 5900HS
  • RTX 3070 Laptop GPU (80W)
  • 24GB DDR4-3200 (8+16)
  • 2TB SK Hynix NVMe (boot) + 2TB Crucial P2 NVMe (games)
  • 90Wh battery + 200W power brick
  • 15.6" 1440p 165Hz IPS Pantone display
  • Logitech G603 mouse + Logitech G733 headset
"Hex": Dell G7 7588 (2018)
  • i7-8750H
  • GTX 1060 Max-Q
  • 16GB DDR4-2666
  • 1TB SK Hynix NVMe (boot) + 2TB Crucial MX500 SATA (games)
  • 56Wh battery + 180W power brick
  • 15.6" 1080p 60Hz IPS display
  • Corsair Harpoon Wireless mouse + Corsair HS70 headset
"Mishiimin": Apple iMac 5K 27" (2017)
  • i7-7700K
  • Radeon Pro 580 8GB (basically a desktop R9 390)
  • 16GB DDR4-2400
  • 2TB SSHD
  • 400W power supply (I think?)
  • 27" 5K 75Hz Retina display
  • Logitech G213 keyboard + Logitech G203 Prodigy mouse
Other tech: Apple iPhone 14 Pro Max 256GB in White, Sennheiser PXC 550-II, Razer Hammerhead earbuds, JBL Tune Flex earbuds, OontZ Angle 3 Ultra, Raspberry Pi 400, Logitech M510 mouse, Redragon S113 keyboard & mouse, Cherry MX Silent Red keyboard, Cooler Master Devastator II keyboard (not in use), Sennheiser HD4.40BT (not in use)
Retired tech: Apple iPhone XR 256GB in Product(RED), Apple iPhone SE 64GB in Space Grey (2016), iPod Nano 7th Gen in Product(RED), Logitech G533 headset, Logitech G930 headset, Apple AirPods Gen 2 and Gen 3
Trash bin (do not buy): Logitech G935 headset, Logitech G933 headset, Cooler Master Devastator II mouse, Razer Atheris mouse, Chinese off-brand earbuds, anything made by Skullcandy
7 minutes ago, Mug said:
Two options:
Not as common as u think. many of the 2.5" doesnt have sata just one of thos weird thin wire u see in laptops
and he didnt need a card just needed to have an actually Type A INSIDE the case.
