Do wireless n devices slow down a wireless ac network?
On 2/24/2017 at 0:06 AM, KeitaRR said:ok, if i'm understanding this correctly it slows down the ac device in the sense that ac and n devices have to take turns communicating to the router, and sometimes the ac device has to wait until the n device finished its communication (which is in wireless n speed). but when it's the ac device's turn it'll run in ac speed. if that's the case then the real world speed of the ac device would be running somewhere between wireless n speed and wireless ac speed (assuming there's a wireless n device connected in the same network)? Please correct me if i'm wrong
and the follow up question would be how big or how long is one "communication" between the device and the router? im thinking if the size of one "communication" is fairly small then it won't impact the speed as much
Yes that is the gist of it. There are a lot of other things to take into consideration too. For example, a wireless N device can be faster than a wireless AC device. This might happen when a wireless N device is really close to the access point, but the AC device is really far away and has to change to a lower data rate to get a clean signal. In those situations, it will be the AC device that is slowing down the N device.
In order to create some kind of fairness, most access points will try and let slow and fast devices send an equal number of frames over the same period of time. So if both devices want to send 20 frames, they will be interleaved so that device1 sends its last frame just before or just after device2 sent its last frame. In those situations, wireless N really will bring down an AC device to the same speed. But it will only be that way for the duration where both devices want to send data.
Some access points have a feature called "airtime fairness", but since there isn't any real standard for how it is implemented it is usually only implemented for sending data from the AP to devices, and not for when devices want to send data to the AP.
What airtime fairness does is that instead of saying "each device should send the same amount of frames in a given time", it says "each device will get equally long time slots". So if your AC device can send 4 frames in the same period of time the N device can send 1, your AC device will receive data 4 times as fast as the N device even though both want to receive data at the same time.
There are a ton of different scenarios where N/AC mixed networks will behave differently and it will impact performance. That's why it is so hard to say "having an N device will reduce the speed of your AC network by Y%".
But in simple terms you can say that while an N device is transmitting data on your network, your AC device will perform somewhere between N and AC speed.
Where in-between N and AC does it land? Nobody knows. It depends on your equipment, environment, how much data each device want to send/receive, how long that will take and a lot of other factors. I would not be too worried about it though.
