Corsair AX860i (NO Power Cable)
dreamhacking
Go to solution Solved by STRMfrmXMN,
5 minutes ago, dreamhacking said:
Hello guys,
i bought this PSU from someone and he does not have the power cable (the black cord) provided.
Can i just use my Antec 500W Power Cable to power this AX860i?
Yeah it'll work
Hello guys,
yep
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
Yep. Could use one from a TV if you needed to. Just make sure it's not running off extension cords.
i used my monitor cable and it works so i guess yeah.
PC || CPU - I5 3570K @4.5ghz|| Motherboard - Asrock Z77 extreme 4 || CPU Cooler - Corsair H100 || RAM - 1x8GB Vengeance Blue - XPG Adata 2x4GB's (16GB) || Graphics card - EVGA GTX 970 superclocked ACX 2.0 SLI || Storage- SEAGATE FIRECUDA 1TB ||PSU- Corsair AX750 watt gold rated|| Case- NZXT 340 WHITE
Hello guys,
Yeah it'll work
|PSU Tier List /80 Plus Efficiency| PSU stuff if you need it.
My system: PCPartPicker || For Corsair support tag @Corsair Josephor @Corsair Nick || My 5MT Legacy GT Wagon ||
