Suggestions on a case for mini itx case for watercooling
VMBRA_
Hello, I have been searching for a Mini ITX  case that can accomodate a 240mm rad, and maybe also one of those new flat reservoirs from ekwb (preferrably also a 240mm one, if not, a 120mm one will do).
I already looked these cases Raijintek Ophion Evo, Raijintek Ophion M Evo, Corsair crystal 280x, Phanteks Evolv Shift / Shift Air (this one cant accomodate most of the gear i want, without modifications to the chassis), Silverstone LD03/LD03B.
I am planning on using an Asus rog strix Z390-i Motherboard, and a MSI 1660ti Gaming X, and later on upgrading to a 2080/2080ti with custom watercooling.
I find the raijintek Ophion M Evo to be my best option, but suggestions are always welcome.
Thanks in advance for any help/feedback provided.
Most of these cases are mATX. Is that because you're making sure it has enough room for watercooling in the future?
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Yes, it is. I want to make it as "portable" as possible, while allowing it to be watercooled. I plan on doing a full EKWB quantum build with their new rectanguçar/square pump+reservoir combo units in the future. Meanwhile I am going with the h100i AIO I currently own.
Assuming you want to custom watercool both your CPU and GPU, you'll probably want two 240mm rads, as one 2080ti is enough to saturate a 240mm RAD in some overclocking cases.
The Silverrstone RL0* is inverted, but can hold dual 240mm rads (or a 2870 at the front) and is relatively compact.
https://pcpartpicker.com/product/wd6qqs/silverstone-rl08bw-rgb-microatx-mini-tower-case-sst-rl08bw-rgb
https://pcpartpicker.com/product/M9WBD3/silverstone-rl08br-rgb-microatx-mini-tower-case-sst-rl08br-rgb
A more traditional aloyout would the MEshify C Mini
https://pcpartpicker.com/product/JsKcCJ/fractal-design-meshify-c-mini-dark-tg-microatx-mini-tower-case-fd-ca-mesh-c-mini-bko-tgd
