will this work with my tx650m
Solved by jonnyGURU,
15 hours ago, mash104 said:my motherboard i plan to upgrade to shows that it needs an extra 4 pin eps power besides just the normal 8 pin and was wondering if the cable in the link would work with my tx650m and provide the extra 4 pin.the tx650m is listed under the COMPATIBILITY list.
Like others have said, odds are the motherboard will work without issue with just the 8-pin. But if you want to buy an additional cable, that's exactly the one you want.
