Help, Sudden Unstable OC?!
Go to solution Solved by Jurrunio,
does it work if you use fixed again? tbh adaptive is better when it comes to saving power, but turning it off is even better.
Well I have a horror story to tell you first.
I have built this system in May of 2017. New first build ever. (Build in sig.) Did some research on overclocking CPU, RAM, and GPU. So thought go in order of research and understanding what I've read.
So OC'd my CPU for an hour it took me to OC to find my max which is 5.0GHZ on an 7700K with a voltage of 1.33V on FIXED voltage. So now that I found max OC I switched to adaptive. (This is where I get confused, EVGA bios I guess) On adaptive it is set to 1.305V with a +25 offset = 1.33v. If that is correct. Also set only the offset at +80 which makes it about the same voltage as if I were to set it. This is with Arctic MX-4 thermal paste with an EVGA 280mm CLC AIO. I had solid temps at max load/100% around 65c including OCCT stress test, Intel burn test (standard and high) and cinebench (1036 score).
Today something scary (to me) happened during playing black ops 4. I freeze and BSOD of WHEA UNCORRECTABLE ERROR. Which I hear is unstable OC. I thought just a fluke cause I've had it OC since I built it. Some other error codes as well but all pertaining to unstable OC. As nothing else is overclocked yet cause I'm waiting on new RAM. Not worried about GPU yet, I'll do that last once everything else is good to go.
I'm so frustrated as of now. I've been retrying & testing my OC since 11 this morning. [EST] Temps are just took insane even with a dirty OC at 1.35V which I would like to stay at or below. Time of posting this I have set it back to default/stock and getting temps on a OCCT medium set test of 85c = failing OCCT. My CPU cooler is working fine I checked it out and made sure. I'm thinking of doing a repasting with a new thermal paste tube I just bought. "Arctic Silver 5" so it's not so watery like MX-4. Thinking thicker may spread better, was recommenced this thermal paste by a previous post about which thermal paste to get.
So anyone know about how adaptive works or if fixed vcore is better?
I mean overclocking is just adjusting vcore to have enough power to keep cpu temps in control and clocks stable in gaming and everyday tasks correct?
Any ideas on what to try?
Should any CPU settings be turned off?
Turbo
C-states
whatever else there is (don't know the rest off hand)
I know this is a long read, sorry about that. Just trying to explain as much as possible.
Any help to fix this is greatly appreciated. Hell I'll even let you remote.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/
Desktop benching:
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11975952
Could be silicon degredation from running at 5ghz for so long.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11975964
@Jurrunio I will try that and report back.
@asand1 Does that really happen?
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976019
I mean before overclocking it I delidded it and used liquid metal. Tested it using a dirty OC 1.35v and 65C-67c highest temps over an hour on realbench.
I'll try fixed if its better than adaptive. I'll report back
quote or or mention the person if you want them to respond. To quote, click the icon on their response that looks like the reply symbol for emailing, and to mention them, just type the "@" sign and then type out their name
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976032
Right my bad. Did I edit right?
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976166
Well, just re-edit it, remove the quotes, and put the "@" and their name. If you "@" them, you dont need to hit the reply icon
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976350
current alone can cause cpu degradation, just change back to fixed or go down to 4.9. Really convoluted and exaggerated post.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976367
Yeah, I just tried to explain it best I could. Could be shortened I guess. I'll try the fixed after I repaste with new just to have a fresh go.
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976388
Tbh just using the CPU alone will degrade it, but 5GHz 1.33V isnt enough to make it degrade especially fast. Maybe the old voltage is just right on the line of stability?
Desktop benching:
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976429
i'm thinking the same, his offset isnt giving the same amount of voltage, even a change from 1.33 to 1.32 is enough to cause instability, and 1.33 is insanely low for 5ghz.
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11976439
Yes 1.33v is exact for 5.0ghz. I'm running now on fixed voltage and ran 3 hour occt medium data and 20 minutes of linpack and no errors temps highest were 70c, just for moment though. Now we just see what happens in game. Will report back.
Yes, youre probably right adaptive I think is the problem. Either I don't know how to work it or the offsets and target are not doing what I read they should be doing. I'm now running fixed 1.33v. 5.0GHz Running aida64 while writing this and at 68c-71c. So I believe were good will report back after gaming.
Edit: So during gaming I had no crashes and temps were from 60c in beginning and dipped down the 56c-58c after an hour of playing. Very surprised I am. Maybe I have a better chip than I thought.
Thank you for you're help. Fixed/override voltage is making a major difference. From now I'll always use override.
https://linustechtips.com/topic/996078-help-sudden-unstable-oc/#findComment-11977063
