What power supply should I get ?
Solved by DailyProcrastinator,
Those PSU's aren't great, If you are looking at a budget PSU get the Corsair CXM 450W, it will be enough for your system and is a better option then what you have selected. A cheap PSU can fail prematurely and take other components with it. Also, efficiency does not equal quality, just because a PSU is 80+ gold rated or higher does not mean it is made with quality components.
https://pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na
