Is this is good deal for a power supply and does it work well?
Ehrix
So I was on newegg and saw there was a combo for a 2070 and and a power supply for -$80. The powersupply Is an EVGA Supernova g1+ 650watt. Is it good at all, or should I stick to corsair's RX series power supplies?
Current Pc Parts:
-CPU: Intel i7-9700k
-GPU: EVGA RTX 2070 black edition
-CPU Cooler: NZXT Kraken x62
-Mobo: Asus z390-E gaming
-Ram: Corsair Vengeance RGB pro 32g @3000MHz
-Storage: Samsung 850evo 256Gb
-Storage: Toshiba 1Tb 7200rpm
-Case: NZXT H500
-Extra: NZXT Hue 2
The G series from EVGA is at least mid range, with some high tier offerings, so I'd say it's a good deal. I believe that power supply is a $65 unit, so you're basically getting a free PSU and a discounted 2070.
Primary PC:
Well the G1+ is still a very good PSU.
Personal Desktop":
Luna, the temporary Desktop:
what about a g1+ vs a g3? What is the difference
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
The G3 is just the latest revision though there were minor issues with its concept and 'quality wise' they even out.
If you go to our PSU Tier list you'll come to know both are rated Tier 2 which is still by all means good picks for a system.
Personal Desktop":
Oh I forgot the tier list existed :P
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
Should I get something from the tier 2 or tier 1 list? Is there a difference?
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
Either 1 or 2 are ideals for personal machines.
Personal Desktop":
Do you think I should wait for black Friday, buy a processor and motherboard and then near the "end of year holiday season" buy a graphics card? Or get this bundle now
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
It really depends on what kind of computer you want, a RTX 2070 is a GTX 1080, is that the level of performance you want from your GPU? what is the rest of your PC going to look like? Is it only for gaming?
Personal Desktop":
CPU: Intel i7-9700k
MOBO: Asus Prime z390-a
CPU Cooler: NZXT Kracken x62 w/ stock fans
GPU: RTX 2070
Fans: 2 NZXT AER RGB fans
Case: NZXT s340 Elite White
Ram: Corsair Vengeance Pro RGB (2x16GB) 32GB 3000MHz CLS15
Storage 1: Samsung EVO 850 evo 256Gb
Storage 2: 1b Toshiba 7200 RPM
Extra: NZXT Hue 2
Keyboard: Razor chroma blackwidow v2
Mouse: Logitech G502 Spectrum
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
Yes it is mostly for gaming but with a little school work mixed in. Mostly on chrome though in the future may use programs. Like some sort of CAD.
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
It looks pretty fine to me, you could still go i7 8700K + z370 instead as it performs much the same for cheaper (not to mention the i7 9700K is incredible hard to find available).
I'd just try to stay away from Razor products and favour a Corsair mechanical keyboard.
Personal Desktop":
I already own that keyboard and mouse. I'm using them right now :P
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
Ok so I wanna confirm this. I should get the EVGA rtx 2070, EVGA superNOVA 650 G1+ 80 gold plus power supply over a Rx650 gold plus rated power supply thats on sale while waiting for a RTX 2070 to become on sale.
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
It won't matter which way you go here, both will work out.
Personal Desktop":
ok thx for the help. I'll work on which one I should buy though learning towards your advice.
I had a intel i7 8700k and a z370 but returned it for the i7 9700k, was going to wait till when the prices drop.
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
Eh I don't think this was a very wise thing to do, the processors are he same, the Hyper-Threading on the i7 8700K makes up for the extra 2 cores of the nonHyper-Threaded i7 9700K.
Benchmarks shows same performance across the board... but no point crying over spilled milk hehe, wish you good luck with the system.
Personal Desktop":
Thx!
Current Pc Parts:
-Case: NZXT H500
-Extra: NZXT Hue 2
I dislike the EVGA G1+ as it has no surge protection and in accurate power ok time.
Not something you’d prefer with an unstable power grid or with common lightning.
The RM550X is better.
