RTX owners: please post 416.81 driver improvements
xg32
Personally, my second monitor stopped flickering, and i can finally play ff15 and sotr without crashing, still problems with hair in ff15, ugh, i dont have the problematic gsync issues to begin with.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
My screen flickers in desktop sometimes so that's not fixed. I have to put in and out the display port cables for them to stop. Still getting blue screens etc.
Main PC:
CPU: Intel Core i9 13900KS SP 116 (124P-102E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC8 1.525V (real voltage 1.425V + - Temps 85-90 P-Cores, 70-73 E-cores)
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8600Mhz CL38 (OC from 8000Mhz CL40)
GPU: RTX MSI 4090 Suprim X with EKWB waterblock
Case: My own case fabricated out of aluminium and wood
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
WiFi: BE202 WiFi 7 Tri-Band card module
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 240Hz Ver. 5120x1440 with G-Sync and Freesync Premium Pro 1008 Firmware Ver, and 1x Electriq USB C 1080p 15'8 inch IPS portable display for temperature and stats, MSI 23'8 144Hz G-Sync
Fan Controllers:  6x AquaComputer Octo with 5 temperature sensors
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3rd Loop: 1x 240mm PE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY)
Total: 5x pumps and 13x radiators 50x 3000RPM Noctua Industrial fans
Keyboard: Razer BlackWidow V3 RGB - Green switches
Sound: Logitech Z680 5.1 THX Certified 505W Speakers
Mouse: Razer Basilisk Ultimate Wireless with charging dock
Piano: Yamaha P155
Phone: Oppo Find X5 Pro
Camera: Logitech Brio Pro 4K
VR: Oculus Rift S
External SSD: 256GB Overclocking OS
LaptopMSI Titan GT77HX V13RTX 4090 175W, i9 13980HX OC: P-Cores 5.8Ghz 3 cores and 5.2Ghz 5 cores and E-Cores 4.3Ghz, 192GB of RAM @5600Mhz @3600 (chipset limit),
12TB (3x4TB) of NVMe, 17'3 inch 4K 144Hz MiniLED screen, 4x 17'3 ASUS portable USB-C Monitors 240Hz, Creative Sound Blaster G6 Sound Card, Portable 16TB NVMe in TB4 enclosures (8x2TB), Razer Basilisk Ultimate Wireless with charging dock gaming mouse, Keychron K3 gaming keyboard with blue switches low profile, Logitech Brio 4K Webcam.
Hand held: ROG Ally with XG Mobile RTX 3080 with Keychron K3 low profile keyboard (Blue Switches) and Razer Hyperspeed V3 mouse and 4TB NVMe upgrade (WDBlack SN850X), with 100W 20000Mah power bank and portable monitor ROG XG17AHP 17'3 inch 240Hz with built in battery, and 518Wh Power station for Camping.
ugh sorry to hear, do you know if the bsods are caused by the gsync or the dual display?
Not sure actually. It could be the G-Sync. But the recent driver was supposed to address it and I'm still getting them.
Main PC:
Piano: Yamaha P155
VR: Oculus Rift S
