How many case fans i need
robby999
I have 2 fans one exhaust one intake
Corsair carbide spec o4
Ryzen 2600
1070 inno3d x2
Msi b450 gaming plus
Ryzen 2600
1070 inno3d x2
This case have more room for more intake?  The single intake is already half covered by the front shroud.  I would at least put in 2 fans in the top as exhaust, so you create a Negative Pressure Environment - which means it will suck in air from any crack it can...I think you are going to need it.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
2 minutes ago, Firewrath9 said:
thats enuf. mabye 1 more intake
From the pics, I THINK it can put another in the bottom but its nearly completely covered by the front shroud.  If it could fit another intake, I would put a fan everywhere you can.  Im a fan guy though.
Negative Pressure= Dust in all the places you don't want it to be. Ideally you only wanna pull through the front or wherever there is at least some kind of mesh or filter in front
Folding stats
Vigilo Confido
I used the words so likely I know the results ;) - it also ensures no hot spots building up, which will happen with that CPU/GPU spinning hot air in that case begging to have cold air in, and hot air out lol.  There is optimal, then there is enough for case cooling and I am always seeking optimal.  The case itself is a complete design flaw I personally would avoid at all costs.
Currently at my house I have 1 PC set up as Positive, 1 PC set up as Neutral, and 1 PC set up as Negative.  The Negative I clean out every 2 months.  The Positive every 3-4 months, the Neutral...still spotless after 1 year.
5 hours ago, robby999 said:
2 intake and one exhaust will do ?
So one more intake ?
The case comes with 1 stock front intake. 1 front intake and 1 exhaust is enough but 2 front intake and 1 rear exhaust would be optimal.
If you would like fan recommendations, tell us where you're shopping / located, and your budget.
India 500 inr
I have a circle 120 mm red fan 449 inr on amazon for exhaust 1000 rpm
And front is stock case fan corsair
920 rpm
7 hours ago, robby999 said:
India 500 inr
920 rpm
The stock case fan included with the Spec 04 goes up to 1300rpm.
At that price point, there isn't anything that stands out above the rest. The same Sickleflow clone from Ultima seems a bit cheaper. https://www.amazon.in/ultima-Quality-Cabinet-Cooling-Connector/dp/B0799LN1G8/ref=sr_1_6?s=computers&ie=UTF8&qid=1541251691&sr=1-6&keywords=120mm
They're noisy but deliver decent airflow at high rpm or subpar airflow at low - med rpm.
Ultima good company ?
I dont want any led fires
The Sickleflow and its various clones from Ultima, Circle, etc. -- they're the same fan.
