So I plan to get a Ryzen 5 1500x and the MSI B350M Mortar motherboard. I want to do some overclocking nothing to extreme. My current PSU is an Evga 450B.
Would this be sufficient to get a light OC? My full specs currently are:
i5-6400
MSI B150 Gaming M3 Mobo
G.skill 2x 8gb 2400 Ram
Nvidia 980Ti Founders edition OC'd +250 on Core and +350 on Memory with +55 on Voltage
Evga 450B PSU
Leaving for work now so once I get back I will reply. Thanks for the help!
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/
considering how little price difference is between the 1500x and 2600, I'd say that's not a good idea.
MSI's B450 boards are much better. If you stick with 300 series chipset boards, go for Asrock stuff
Desktop benching:
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923627
Agreed ^^
About the PSU, that’s a relatively low quality PSU. If you have the budget, I would try to upgrade to something a bit better. Corsair’s grey CXM series is good quality for the price
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923634
I will go with the 2600 if it is still the current price next friday when I have my big check for working a pay period straight. I am also trying to stick with MSI mobos so theres less of a chance I will need to reinstall windows.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923641
just because the mobo is the same brand doesnt mean you can get away with not reinstalling the OS. It depends more on luck
Desktop benching:
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923644
1 minute ago, Cereal5 said:
Agreed ^^
I know I know lol. Its one of the things I've been wanting to upgrade. I plan to have mom get me a good one for Christmas this year. I just need to send her the amazon link. I was planning to get a corsair RMx 650W 80+ Gold.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923648
I know just hoping that staying with MSI will help with my luck. I need to remake my USB installer so just in case I have it.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923654
That’s an even better choice.
Windows 10 is pretty good about sending new hardware. I changed my CPU/MoBo and had no problems
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923662
Good. I really don't want to reinstall lol. Not gonna lie I'm pretty lazy. I do plan to get either to 1500x or 2600. Just depends on prices next friday. I wont have much left for a motherboard thats why I'm going with cheaper ones.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923681
$250 will get you a 2600 and a good enough motherboard. You can work it out with $225 or so also
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11923882
I'm just waiting for friday. Either way what are your opinions on the wraith spire cooler?
It's good enough. Plenty for stock speeds. Most people even do mild overclocking on it. I would try it out, and if you feel you need a better cooler, then you can get one, but it might fit your needs.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11931106
Thanks Cereal5! You and Jurrunio have been a big help. For now I am getting a 1500X and MSI ProSeries B450M M.2 Mobo.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11942383
whew you went with a b450, I think if you had got a b350 you would of had to do some bios update or something. Honestly if you can spend the extra money get the 2600, though if you're in a pickle the 1500x is fine.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-11942677
  • 3 weeks later...
I was in a pickle and did end up getting the 1500X but she is pushing through anything I have thrown at it. I'm currently trying to OC it to 4.1 but it just wont push up that high.
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-12013135
whats your cooling? If you don't good enough cooling then its not gonna push any further, obviously. And if you do have a realllllyyy good cooler than you got a bad chip from the silicon lottery.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/990248-cpu-and-mobo-upgrade/#findComment-12013447
