Is it possible to run a game in a higher resolution than the monitor?
Solved by Mira Yurizaki,
If you need help finding where it is.
Fankywanky ·
Posted in General Discussion0 -
Seosamh_101 ·
Posted in Windows2 -
2
1
2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
