Help: Wife borked computer with M.2 SSD
KappW
Hi! So, *someone* in the household tried connecting a M.2 SSD by sticking it into a SATA power connector. It never powered up after this -- not even briefly -- and was completely dead, even when aforementioned SSD was removed.
I've tried disconnecting and reconnecting everything, but it still doesn't power up. No lights, no beep(s), no nothing.
The PSU seems fine, and starts when I try the short trick between the green wire and ground with a paperclip. The fans, HDD and LEDs do power up when I do this, but the computer does not boot. A LED marked DRAM does also light up during this.
LEDs also flash very briefly up if I pull the ATX power connector halfway out and wiggle it a bit.
Absolutely nothing happenes when all the power connectors are properly in place.
I've tried resetting CMOS by removing battery, removing one or both RAM sticks, removing GPU, removing HDD etc., but still no dice.
Anyone got any idea about what the problem could be, or other tricks that might work?
Update: Tried with a new PSU, problem persists.
Hardware:
Mobo: MSI B250M Bazooka, Socket-1151, mATX, B250, DDR4, 1xPCIe-x16, M.2
CPU: Intel Core i7-7700 Kaby Lake, Quad Core, 3.6GHz, 8MB cache, 65W, 14nm, OEM/tray
PSU: Cooler Master B500 V2, ATX 12V V2.3, 80Plus, 1x 4+4 CPU, 2x 6+2pin PCIe, 6x SATA, 3x Molex
Cooler: Cooler Master Hyper TX3 Evo
RAM: Crucial DDR4 2400MHz 8GB, 2x4GB 2400MHz (PC4-19200) DDR4 CL17 SR x8 Unbuffered DIMM, 288pin
GPU: MSI GeForce GTX 1060 6GB OC
HDD: Seagate Firecuda 1TB 3.5'' SSHD, SATA 6.0Gb/s, 7200RPM, 64MB cache, 8GB Flash enhanced
EDIT: Added PSU to the hardware list.
i think your psu might be shorted.
if you're lucky the psu fuse might broken, just replace the fuse.
Not sure how that could fry a motherboard, if it shorted then it would stop back at the PSU.
Other than that I am vacillating between laughing my ass off and horrified someone would actually think to do that!
Least you have a sweet story for years, that's worth more than an SSD anytime :)
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Point number the first: this post made me laugh more than anything else I've ever seen on this forum.
If you have another power supply lying around,I'd try that. If not, I'd try and pick up something insanely cheap on craigslist for just a single boot. Doesn't need to be high wattage, just needs to work. If that didn't work, I'd say it's a bad motherboard.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
I would guess she damaged the internals of the sata connector and it is constantly shorted. She could have also shorted the PSU.
Curious why he didn't list the PSU but listed the rest. The PSU is kinda integral here.
If it's modular, replace that cable then.
OnePlus:
Other Tech:
Try cutting off the sata connector header.
sudo chmod -R 000 /*
Oop, copypaste fail. Ive added it now. Thanks for pointing it out!
Tried opening it, but the only fuse I can find is soldered on. Not able to see if its blown or not. Would the PSU still run if its blown? As mentioned, it starts up when I try shorting with a paper clip
Haha! Yeah, of all the technical f-ups we've had here over the years, this one is definately one of the better ones ?
Havent got any lying around, but Ill go out and buy a cheap one tomorrow. Thanks!
this is the best start, since it fried the 12V rail likely shorting the 5/3V down graders, the system wont work properly
having recently experienced something weird a jumped PSU spinning up doesnt mean its good.
1- old 700w OCZ idkmodel whocares. i only use it for stuff, and jumped to prime the system with out dealing with the mobo connector (i just unplug at the wall to disconnect everything)
2- building new system as a gift with old part i dont use any more, waiting on the amazon order to finish the system (new psu most importantly for this)
3-couldn't post the used mobo, thought i was served a lemon.
4-2nd' old psu for similar purpose's but only 500W POS idk,  and same thing.
5- tried the psu from my down at the time system and the 850w worked.
6- both psu that wouldnt post, spun up/jumped fine, but wouldnt post the mobo
estimated wattage use of the system at load was like 99W, or something redic low
since gift reciever doesnt need a GPU,  i subbed in a decent old cheap APU
UPDATE: Got a new PSU today, but the problem persists. Still no life whatsoever. I guess this means that the mobo is likely the problem? On the plus side, I've got a spare PSU now for a later rainy day :)
Edited by KappW
spelling
