Are they providing it for free?
https://linustechtips.com/topic/988424-isp-modem-worth-using/#findComment-11905319
11 minutes ago, The RGB scrub said:
Yes they are providing it for free
check whether it is really free or if you have to pay a monthly rental fee for it. I haven't ever seen a modem router actually be free. Also check whether they are being clever with their pricing - instead of admitting that the modem is a monthly rental, they might instead consider it part of the basic service, but give a "discount" if you bring your own. If you can either get a discount, or they are charging a rental fee, then having your own modem will usually pay off within a year (Most US ISPs charge around $10/month for the modem rental, and for $80 you can get a pretty good modem on the side)
The only reason it sometimes makes sense to stick with the ISP's modem is if you are also getting phone service from them and it is fed from the modem - in that case you need a modem with similar functionality and they can be hard to buy on the open market.
You can see the list of modems that Spectrum currently allows here: https://www.spectrum.net/support/internet/compliant-and-non-compliant-modemsgateways-charters-network/ - also this page has wording that implies they will offer a modem for free but charge for a "pre-configured Wi-Fi Router". If this really is the case (modem is free and there isn't a discount for bringing your own) then I would take the modem they offer and get my own router.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/988424-isp-modem-worth-using/#findComment-11905344
