Right, I originally made a post about a "CPU" Bottleneck and was suggested to upgrade to a better CPU. So i did, i upgraded from an i5 6500 to a Ryzen 5 1600 as i got it for a discounted price and i thought that would fix my 50% GPU usage max in my games but still no luck. I tried playing fortnite at max settings as i previously tested and to my surprise i'm having similar results and can not play any game with a GPU usage higher than 50% i play at 1920x1080 @60hz.
I seriously can not figure it out and would love some advice and help from you.
Core Specs:
Ryzen 5 1600
8gb DDR4 @2666
GTX 1080 FE
https://linustechtips.com/topic/988275-can-someone-help-me/
Is your PC's power plan set to high performance or balanced?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903708
When gaming can you pull up task manager, details tab, find the game.exe file right click and set priority to HIGH and see if that forces the GPU to more usage?  Maybe this will narrow it down to a software issue?
Also - can you download Unigine Heaven and run a benchmark should force the GPU usage to 100% to ensure it does work?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903797
It wont allow me to set it to high priority it says acess denied
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903849
That is because single thread wise the i5 6500 is actually superior to that  of a stock Ryzen 5 1600 while 4 cores still does the job fine enough.
The reality here is that you never upgraded you simply sidegraded, kinda never made sense what you did, I'd personally have just picked a second hand i7 7700 to max out the GTX 1080.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903853
I also got the 1600 for video editing and the option to stream is always there
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903860
right click game and run as administrator?
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903876
It'd be a shame finding out that the i7 7700 heavily outperforms the Ryzen 5 1600 on Adobe Premiere and Sony Vegas due to iGPU hardware acceleration and quicksync igpu streaming is a thing.
Moral of the story is, do a better research before buying stuff, best you can do is learn now how to overclock the CPU to its maximum and the Memory also, make sure your OS is healthy and go on with it.
Personal Desktop":
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903880
Thats besides the point, it should be using 100% usage most of the time regardless of the unless it cannot handle it
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903888
You clearly need so much to learn if you expected your ryzen 6 cores to be at 100% usage on gaming alone.
Personal Desktop":
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903892
11 minutes ago, DanTheMan09 said:
Nope it says it even when i tried that
What operating system?
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903929
Did you download Unigine Heaven and run a benchmark?  That should force 98+% usage.
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903935
1 minute ago, DanTheMan09 said:
its 98-99% usage and win 10 unactivated itself after changing cpu and mobo
What monitor, be specific
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903946
The monitor should not matter
What monitor - if your GPU doesn't need to be going any faster than it is, why would it?  You sound like you have zero environment control in Windows 10 (Im sitting here staring at a Watermark on my bottom right as well.) with priorities, UAC, etc.  If you cant do those things I doubt you can set your power settings as well?
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903959
This will be my guess before I would say its a software issue and you didn't reinstall windows 10 with this CPU and mobo change (watermark, so didn't activate or didn't reinstall) - next thing I would say is reinstall Windows 10, clean drivers etc.
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903962
on the nvidia panel i set it to prefer maximum performance didnt realise there was one for windows too
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903963
Im gonna work on that now
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903966
So let me help you - what monitor, and have you set Windows 10 power plan to Performance?
I only have like 10 minutes before my wife is going to tell me to get off the PC lol
So reinstall Win 10, fresh drivers, game etc, that's what I would do to completely eliminate any outlier issues. :)
https://linustechtips.com/topic/988275-can-someone-help-me/#findComment-11903971
