I am looking to build a PC for Gaming and Content Creation with little concern for price. I am in Orange County, California, USA.
(Gaming 4k Max settings High FPS)
(Video/Photo Editing 4k)
(Music Production)
Here is my part list:
https://pcpartpicker.com/user/eliyahuofficial/saved/JTP7WZ
I believe everything is there except X2 Intel Optane SSD 800P Series (118GB)
My Questions:
What power supply watt should I get? I am looking at the 1000w Platinum by Corsair for my build. (Basic overclocking will be performed)
I want to run Raid for drive protection and speed I am under the impression Raid 10 is the best option? What is required software/hardware?
Also, I would like to know if I am missing anything and alternative compatibility issues?
And lastly, if I can just get overall advice/ help/suggestions for this build I would appreciate it!
(Experience level: Newb with 100 hours of Linus, Jay, Bitwit, Hardware Canucks, etc.) XD
https://linustechtips.com/topic/986017-i9-9900k-system-build/
2 minutes ago, Technomancer said:
Since you can afford 6 SSDs, why not just get a few PCIe M.2 ones (which can be used as scratch disks since you're using your PC for content creation).
Corsair HX1000i
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882197
a good 750w will do... but the thing is, why even care when you're already spending so much on other things.
If you care about keeping data safe, you should build a NAS running RAID 5 or something like that with many hard drives rather than having everything in your PC in SSDs.
FreeNAS is a good software if you plan on building such NAS yourself. It's easy to build one, find a CPU with integrated graphics, motherboard with multiple PCIe slots so you can add PCIe to SATA expansion cards if needed, and a case that can hold all the hard drives you need.
Instead of having so many SATA SSDs, you should split them up to 'NAS with a bunch of HDDs for long term storage', 'about 1TB of SATA or PCIe SSD (including M.2 and PCIe form factor) space for things you always need', and '~500GB of PCIe SSD space as scratch disk during the editing process'.
Desktop benching:
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882206
Ugh
Is this a content creation PC or a super low storage high failure pc with the most expensive parts you can find.
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882230
Why 6 512gb SSDs instead of 3 1tb's? Or a 2tb and a 1tb. For that price you could throw any high end PSU in there (the one selected is fine) and be okay.
Another consideration is to cut your budget in half and give me the other half. Would be a dope ass move brother
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882256
Corsair HX1000i
I didn't think about that, that might be better. Thank you!
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882268
Power supply: I read something about reliability with low Idle watt consumption with high watt power supplies. so that was my concern.
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882270
16 minutes ago, JohnDongus said:
Ugh
Well 6 SSD at 512 in raid 10 is about 2tb of storage if I had a normal storage setup everything would be okay will all my components.
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882271
False, such problem doesnt exist. It can cause low efficiency, but that won't hurt the PSU or any other PC component. Just your power bill if you let it stand idle all day.
Desktop benching:
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882280
14 minutes ago, Brooksie359 said:
I would go for a x299 or x399 build if you are doing a content creation build. At 4k the cpu isn't going to be the limiting factor so you really don't need the super high single threaded performance of the 9900k.
The focus is on Gaming then content creation. Anything will work better than my i3 6gb ram laptop (somehow can edit 4k) XD
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882284
Id only have 1 tb hard disk for backup (External)
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882288
For the same price you can get two much faster Samsung - 970 Evo 2.0TB M.2-2280. Personally I wouldn't put them in a RAID 1 array, but one could.
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11882400
I have the Intel 800 118gb m.2 listed due to its far better speeds for OS and desktop. Raw video files and heavy games will be on the ssd's raid or not. I will not be using hard disks.
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11883412
118GB is going to be tight as a system drive and will not perform as well as a 2TB Samsung 970 Evo M.2 NVMe drive. Compare the specs https://ark.intel.com/products/125298/Intel-Optane-SSD-800P-Series-118GB-M-2-80mm-PCIe-3-0-3D-Xpoint-https://www.samsung.com/us/computing/memory-storage/solid-state-drives/ssd-970-evo-nvme-m2-2tb-mz-v7e2t0bw/#specs
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11883597
My question then would just be how do I configure all of my storage? nvme and ssd from Samsung for best performance?
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11885742
I'm a bit confused as the Samsung 970 Evo is an NVMe ssd.
If you get two 2TB Samsung 970 Evo setup one as the boot drive (C:) with the o/s, swap file, applications, scratch, and basic user files (Documents, Downloads, etc.). Use the second ssd to store projects (D:).
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11885774
Samsung 970 PRO m.2 - OS, Basic apps, Etc
Samsung 850 PRO ssd - Project files, Etc
But my question is Raid? Should I even consider it? Or just have the simple plug and play storage setup?
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11907102
What capacities?
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-11907158
  • 4 weeks later...
I wouldn't use RAID unless downtime or loss if immediate work was expensive enough to justify a second drive for RAID 1. Just make sure you have good backups regardless of your primary storage scheme.
https://linustechtips.com/topic/986017-i9-9900k-system-build/#findComment-12005263
