Suggestions on cooler for thin mini itx?
potato_man
I need a cooler for a build that uses a thin mini itx board. I'm planning to place the components inside an old Asus G2S which has 20mm of height inside it. The motherboard is an Asus h310t with an lga1151 socket and I'm planning to put a 95w tdp cpu in it. Any suggestions for a cooler that would fit inside and hopefully keep the cpu from thermal throttling too much?
welp, if you want to be able to use that CPU and not throttle on high load scenario's, you'll need to vent the heat outside of the case, instead of looking for a internal air solution.
silverstone makes some super slim profile fans i believe, tough watercooling to an external rad is probably the best option. eventough it defeats the entire purpose of going with slim-itx in the first place ?
silverstone's coolers are rated at 65W only :(
https://silverstonetek.com/product.php?pid=418
watercool it
besides, you're doing it wrong to put a 95w (i.e. unlocked 6 core or 8 core) CPU on a H310 motherboard
Desktop benching:
yeah I was actually considering water cooling, however I can't find any waterblocks or radiators that are under 20mm.....
I was thinking of using this waterblock from aliexpress, but it does not have a mountain system, so I thought of 3d printing a mount for it...
Vacuum-Aluminum-Brazing-font-b-Waterblock-b-font-Radiator-Cooling-Heatsink-40x40mm-Computer-Accessories-Water-Cooling.jpg_300x300q75.jpg
