x470 Motherboard for Trident Z / 2700x
Solved by DailyProcrastinator,
Just now, Jurrunio said:1st gen Ryzen with old BIOS suffered a lot from this, but over time new BIOS and CPUs mostly corrected this.
6 minutes ago, tunacat said:
Thanks for the input, I am being just afraid as I am doing my first AMD build and read up some stories on Ryzen being more tricky to reach the rated OC RAM speeds on.
Yes, 1st gen Ryzen had all the issues I can testify to this. But the new Bios updates have fixed everything, I have had no stability issues with my CR7. You won't have an issue with your AMD build and using 3200MHz RAM. Also unlike Intel, you actually see a semi-significant performance gain with high clock speed RAM.
